Calling all you stereo heads ....
I am fitting a 10" Sub doofer in my Monaro - the first sub I have ever owned. I have a second hand amplifier which has no wiring diagram , can anyone give me some clues ? The sub is a Response AA-0434 , I have the power cables sorted out but the speaker connections have me stumped. The speaker is 4 Ohm and the amp has 4 outlets labelled L+ , L- , R+ , and R-
Any clues ????
It's been too long, but google bridging an amp. Don't try it till you can confirm it, but I think you can hook up the l+ and r-...
Re: Calling all you stereo heads ....
like this ??????
(AUST)Mod
Post by (AUST)Mod »
Does the amp have a 'bridge' switch?
(AUST)Mod wrote:Does the amp have a 'bridge' switch?
Not that i can see , theres 4 terminals for the speaker wires , 3 for the +ve,-ve and remote power , and 3 fuses.
(AUST)Mod
Post by (AUST)Mod »
Have a read here: http://www.bcae1.com/bridging.htm
I would have a go with the left positive and right negative to the sub.
I have a spare sub amp which I was given last week which you can use if you want it if this gets too hard.
None of my amps had a bridge switch and I ran the one driving the sub bridged. Mind you it's been fifteen years since I played around with any of that stuff.....
Thanks guys , will give it a go tonight.
NoMAD
Post by NoMAD »
are you ok Blacky? has something happened?
Your working on the Monaro :esmile: :ewink:
Nathan
Foundation Member
basic.green
Post by basic.green »
hi yea use one pos from one side and one neg from other side 8)
building the dream Rick
NoMAD wrote:are you ok Blacky? has something happened?
Nathan
Took it for a drive around the block the other week :thumbsup: owned it for 12 years and that was the first time it has moved under its own steam since I have had it :oops:
NoMAD
Post by NoMAD »
Good to hear at this rate you'll be onto the coupe by 2020, still probably before i finish mine haha
Nathan
Foundation Member
RollinLow
Post by RollinLow »
Left + right - is correct, make sure you switch the filter to low pass or your sub will play full range and not just bass as it is made to do.
I work in the car audio industry so any one looking for help I am here!
What is this filter of which you speak ???? :wtf: :esurprised:
EKjimmy
Post by EKjimmy »
Blacky wrote:What is this filter of which you speak ???? :wtf: :esurprised:
x2 I still haven't figured out how to clean out that filter :roll:
