The difference between an EK auto column and an EJ column?
nes138
Post by nes138 »
Can anyone tell me The difference between an EK auto column and an EJ column?
Re: The difference between an EK auto column and an EJ colum
quite a few EJ is shorter has a different end where steering wheel goes on (same spline) different blinker mechanism and wiring slightly different where steering box bolts to subframe rails it will go in but not bolt out bolt in swap bit of fiddling required
nes138
Post by nes138 »
Thanks mick,
If I swap the pot at the top will the ek (FC) wheel fit?
cheers
not sure that you can swap the top, i would nearly say they are not interchangable but i've never tried and don't know anybody that has, i once made an EK wheel fit a H/KTG collum
My EK sedan had an EH column in it when I got it.
The EK wheel scrapped on the EH honey pot, I was told to stop the scraping or replace the steering column to get rego.
