Help boot hinge spring
fb cruisin
Post by fb cruisin »
I have an FB sedan with a broken boot hinge spring, and I'm having alot of trouble trying to fit a new one, without losing a finger.
Does anyone have any tips or suggestions on fitting this?
cheers Rob
acotters
Post by acotters »
Hey Rob. Mine are stuffed too and I am yet to fix it. I found in the FB shop manual (section 1-25) there is a spec to make a tool to replace the springs. If anyone were to bite the bullet and get some of these made......
Cheers, Andrew.
Whingeing won't fix it.
fb cruisin
Thanks for the pic of the tool Andrew.
Greatly appreciated :D ,
that should be very helpful.
I'll try and make one up.
cheers Rob
blu_fc
Re: Help boot hinge
Post by blu_fc »
fb cruisin wrote:I have an FB sedan with a broken boot hinge spring, and I'm having alot of trouble trying to fit a new one, without losing a finger.
cheers Rob
Hi Rob one of the guys in nsw fefc club has come up with something that might http://www.fefcholden.org.au/cgi-bin/ya ... 68986283ay help you,regards Greg.[/url]
fb cruisin
Re: Help boot hinge
cheers Rob
Thanks Greg, What a great idea.
So all you do is drill out the original pin bolt in these and set the tension with an allen key.
I suppose it would make it easier to give springs that have lost a little tension a bit more of a wind up.
cheers Rob
blu_fc
Post by blu_fc »
No worries Rob if you want the guys ph no just pm me ,cheers Greg
acotters
Post by acotters »
Guys I tried the link and it didn't work. Said the topic no longer exists. Would love to see this other idea.
Regarding the spring tensioning tool, I've decided maybe I should bite the bullet and have sent the drawing to a bloke who is going to make up maybe a few of them for us.
Andrew.
Greg thanks for that great idea.
Andrew try this link...
http://www.fefcholden.org.au/cgi-bin/ya ... 1168986283
same one as Greg posted above except no 'ay' at the end of it.
Stewart
ret
Boot Spring Posts
Post by ret »
Hi guys,
I have more of these available again. This is what they look like:
(note there's a star washer included not shown in that pic)
and here's one as fitted to a vehicle, prior to painting:
These fully adjustable items do not require the special tool shown previously, and won't cost you a couple of fingers trying to fit them!
Price is $35 for a pair, which includes pins, star washers, nuts and fitting instructions. Postage (within Australia) is $5.
Send me a PM if you'd like to order a set.
Thanks,
RET
fb cruisin
finally fitted my adjustable boot spring pins. :D
even if I made the tool my springs needed a little more tension than the factory setting.
I found with my FB it was easier cut off the pressed pin with a 4 inch grinder and re drill.
thanks for the pins Richard
well worth the $$ to eliminate your nasco boot prop :lol:
cheers Rob
acotters
Post by acotters »
Hi Rob / Ret.
Can you have a look at my post under sharing advice & experience please.
I had a go at fitting the bolts which went in fine, but can't seem to get the springs right. I've posted pics there of what I've done, can you tell me what's wrong?
Thanks,
Andrew.
