brake calipers
EK JAY
brake calipers
Post by EK JAY »
Hi :)
has any one put there brake calipers on the rear of the disc rotor insted of the front
of the disc rotor on a hr front end if so whats needs to be done to achieve this
EK JAY SINCE 1990
1962ek
Re: brake calipers
Post by 1962ek »
Hi Jay, If you change them to the back of the rotors it means that you will have to swap them over ( left to right and right to left) OK? Then the bleeders will be on the bottom and you will not be able to bleed them or will have trouble bleeding them. Don't take this as gospel but Athol was going to do the same and this is what he was told..Have you got his number?
Should give him a ring. Graham
EK JAY
Re: brake calipers
Post by EK JAY »
:) Can you pm me his number and i will have a chat to him
i have seen it done some where cant remember where though :? :oops:
EK JAY SINCE 1990
Re: brake calipers
Jay,
You have to swap the stub axles left to right and the same goes for the calipers. Bleed nipple must go to the top.
EK JAY
Re: brake calipers
Post by EK JAY »
:D Thanks Greg :thumbsup:
EK JAY SINCE 1990
