Is there a method to remove one of these that doesn't destroy it?
Can you get a key cut for them to reuse them?
How do you refit them(if its possible)
Thanks in advance,Craig.
Nasco Steering Column Locks
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
Re: Nasco Steering Column Locks
had a prick of a time with mine, ended up drilling out the two bolt heads then when i removed the bottom cup i was able to undo the bolt shafts using a pair of multigrips.
havn't followed up on the replacemet key as yet i was going to take it to a locksmith and get them to make a new key for it.
one of those things on the list
I had one without a key on my flashline EK some years back. I went into local locksmith to ask he he could help and he said he could open the lock and sort out a key for me if I brought the car in. I never got around to it, but he seemed pretty confident.
Alan
Member No.1 of the FB EK Holden Car Club of WA (Woo-hoo
sweet!)
Thanks,gents.Much appreciated.
The thing is,mine is on a HR column,and the top section looks like the ubolt off a muffler clamp,and looks to have the open ends
knocked up hard like a solid rivet,never to be removed.Not at all like those sheer bolts.
Any further info appreciated,I made the stoopid assumption that they would be the same.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
Craig, talk to the locksmith next to me.
Never seen a challenge that has beat him yet & probably has key blanks in stock.
Good call Stanley.
Will do.
The biggest challenge will be getting it off though,I think.
Will do.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
Give him a crack, safes are no problem so a column lock should be a breeze.
