I just need to make a slight adjustment to the prices of the 4 and six mug packages.
I was having a blond moment when calculating and left out a few mugs when adding up
The prices below are now correct, but sill work out cheaper as the quantity increases. The prices for 1 mug and 2 mugs remains unchanged.
Andrea
I had the artwork which I had done a few years ago and thought I would rework it to fit the coffee mugs and keyrings and then make them available for purchase.
I did an initial tester mug to see what the quality was like. I put the FX coupe and one of my paintings onto it and was quiet happy with the look, but I also wanted to see if it was durable. So we had it for about 4 months and used it and it was hand washed, then it was past on to a friend who has a wash machine. He has had it, used it and machine washed it for about 4 months now. It hasn't deteriorated, so at least we know it 's OK.
I have had a further 4 made up, then I met someone who was going to fly back to Oz so I sent the FB one to Scotty.
In the mean time I photographed the mugs and keyrings and put together this little brochure and Andrea has worked out some costings, taking postage and exchange rate into consideration.
Basically the Key-Rings weigh very little so if we send one or up to four of them the postage would be the same.
When sending a Mug I can stick about four Key-Rings into the Mug and they go 'postage free'. The postage rates make it proportionately cheaper to send as the quantity increases, so that is reflected in the prices too.
Costs including postage would be as follows: 1 Mug = AU$ 16.00; 2 Mugs = AU$ 30.00; 4 Mugs = AU$ 50.00; 6 Mugs = AU$ 70.00
Keyrings will be AU$ 2.50 each excluding postage. Postage of AU$ 2.00 for up to 4.
Artworks are as follows: FX Coupe, FJ Woody, FC Convertible, FB Convertible, EJ Coupe, HR Coupe, HK Coupe.
[/quote]
