hi,
i'm changing my ek from manual (aussie 4 speed) to a trimatic. what do i need to do to the pedal box to change it to an auto? i know i need to lose one pedal (i got in efore the smartie's did ) do i need an actual ek auto brake pedal or is there something else i can use?
cheers, luke.
if you can live with the small pedal just use the one that's there and the shonky way to get rid of the clutch pedal if you have carpet, the clutch pedal is on a spring so will stay to the floor if pushed there so push it to the floor and put the carpet over it
