mig wire size
EK JAY
mig wire size
Post by EK JAY »
:) im about to replace a floor pan in the ek wagon and wondering
would .9 mig wire be better to use then .8 :?:
we use .9 at work but we use alot thicker gauge metal then
the floor pan im putting in any info is good :thumbsup:
EK JAY SINCE 1990
muza
Re: mig wire size
Post by muza »
Thats what i'm using with gas mate.
Seems to be doing the trick :thumbsup:
Be interested on others with more experience with thin gauge steels thoughts though
Cheers Muza
Stock as a rock
Not so stock
EK JAY
Re: mig wire size
Post by EK JAY »
:) Thanks muza My mig at home is a gassless 155 amp
works fine with the .8 flux cored wire
on the panel's but wondered if i should step
up and use .9 on the floor :?
EK JAY SINCE 1990
RobinGi
Re: mig wire size
Post by RobinGi »
I've replaced 3 floor pans using .9 and all the settings on the mig set to min
Blew a few holes here and there sepically where the butts didn't line up but in most part it went quite well
Cut up the sections that your've removed so you can get some practice welding them back together before moving onto the real thing
wot179
Re: mig wire size
Post by wot179 »
You would be better off with .6 for panel steel or a floorpan.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
Re: mig wire size
Post by Mick Jagger »
point 6
NOT GASLESS
kmawic
Re: mig wire size
gasless wire is banned every where ,but not here :?
bad for you :thumbsdown:
its like CCA pine in playgrounds ...........WHAT THE FKUDK
kmawic
muza
Re: mig wire size
Post by muza »
wot179 wrote:You would be better off with .6 for panel steel or a floorpan.
I haven't got to panels yet but would .9 be too much heat, causing it to warp?
Cheers Muza
Stock as a rock
Not so stock
wot179
Re: mig wire size
Post by wot179 »
That is definitely a major factor.
its about not having to heat the wire as much to melt it,you have more control over the fine tuning of amps/heat and wire feed with .6 om light gauge metal.
Id be using .9 on anything over 1.6,though.
That said,.6 wire could weld 1.6 withput problems.
And like Jase,I never use gasless.
I reckon its messy and expensive with an inferior weld.I didnt know about the health aspect.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
muza
Re: mig wire size
Post by muza »
Cheers for that wot.
I'm only new to welding thin gauge metal so your help is appreciated.
I have a Lincoln 180c welder with gas. Like you say I personally wouldn't use gasless either. I'm finding even with the settings right down low it probably is still a bit hot, but still ver usable on the 'hidden' stuff. Don't think i'll try my luck with it on panels though!
I find if I'm doing a longish run it'll blow through :roll:
I might get some .6 and see how I go.
Cheers for your help.
Muza
Stock as a rock
Not so stock
ash
Post by ash »
I replaced a sill and floor pan recently using .6 and gas, went very well.
I've got a Trans-MIG 165 which is awesome, you can run very low heat. (I practiced on .5 steel before doing panels)
Re: mig wire size
when i weld panels its not much more than a tack every inch ,a good tack though,and go
over and back again and again,easy on the heat...
and a wet rag to keep it kool ,im probably doing it wrong :(
but the distortion of a nice door is worse,just practice on a FB :)
or a EK :x
kmawic
muza
Re: mig wire size
Post by muza »
Yey I've heard of the wet rag thing.
Do you just cool it straight down once you've tacked it?
Might see if I can get hold of an EK door...............don't wanna wreck an FB one :lol: :lol: :lol:
Stock as a rock
Not so stock
crowbar
Re: mig wire size
Post by crowbar »
If you change wire size do you need to change anything else as well? eg tip size
wot179
Re: mig wire size
Post by wot179 »
Yep,youll need to change tip size as well,but they are cheep so buy a bag of em,you are gunna want a new one before you know it anyway.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
