Painting engine bay
Painting engine bay
With the nats behind us I got enthusiastic about getting my EK to next years in SA.
Out with the engine, steering column and stripped the engine bay.
Welded up the excess holes and primed over the old paint and sprayed with black paint which reacted with the old paint :roll: .
So I have started again with stripping the whole bay again :evil: , this time I am trying to remove all the paint.
I have most of it stripped but am having trouble getting every scrap out of the corners etc.
What would be a primer that will cover any left over paint that I cant remove and won't react?
tm 50
Re: Painting engine bay
Post by tm 50 »
If your using acrylic Trev , the thinners is more volatile and will react can ue retarder thinners to try and slow it down but the best way Go get some isololater acts as a barrier between the paint, make sure you were a mask potent stuff, I know how you feel just finished painting mine yesterday , no reaction , but what a pig of a job getting into some spots. plus one thingled to another and the Fb is spread all over the garage
I'll use 2pac if I have to, thats what the outer panels are painted with.
Trying to get one part done at a time so the car stays looking like a car :roll: .
My plan is to get the engine bay done and back together before doing 1 door at a time.
tm 50
Post by tm 50 »
Tat was my plan as well Trev,Started With The Motor box and engine bay, who was i kidding one thing lead to another, cut the shit chassis repair out and fixed it front end out half the dash more i removed more i found, been cold out there every nite after work working with one arm, but o the up side now can start putting er 2gether now
