After chasing one for awhile I have come to realise I'd have more of a chance of finding rocking horse sh%t.
I'm in Tassie so getting a stainless one freighted down from Queensland will be too expensive.
So, today I called a local metal fabrication business 10 minutes up the road and asked them the question.
Their answer, "Yep, no worries, we often do fuel tanks. Drop the original in and we'll give you a quote.We can basically do it straight away"
I'm a happy camper
ingredient in beer
After a couple of trials we are nearly there. Just need to make sure it fits fine then position the filler neck in the correct position. The first tank they made was good but a little too small. The came in abit on the sides but kept the depth the same. This one is much better.
ingredient in beer
Looks like it will do the job nicely. The only issue I may have is that the original looks like it has some kind of Baffle/divider in it. The new one doesn't. I suppose thats only to stop the fuel slapping around in the tank?
ingredient in beer
You really need some baffles in it , you sure there arent any ? If this bloke is an experienced tank builder surely he would have put something in there ???
Blacky wrote:You really need some baffles in it , you sure there arent any ? If this bloke is an experienced tank builder surely he would have put something in there ???
HE's a metal fabricator, not a tank builder. As for the baffle what will be my issues without baffles?
Definately doesnt have any. The original EK tank seems to just have one plate running across about half way. So if i get these guys to cut a slot across the top of the tank and drop in a baffle then weld the tank across the top I should be OK?
ingredient in beer
