celica 5 speed fitting to grey Motor 138
FB zombie
Post by FB zombie »
Hi
Can anyone please help me ,
I want to swap my M21 gear box (over it) to a celica 5 speed, can anyone please advise what parts I need extra to the gearbox and is tyhere anythingh I need to do to the Celica box?
FB zombie
Re: celica 5 speed fitting to grey Motor 138
you'll need everything except slave cylinder and bracket, flywheel and i think you can use yor pressure plate
so you'll need box, adapter bellhousing, clutch (maybe pressure plate) modified crossmember (should be able to modify the one you have) modified tailshaft and a speedo cable
