Help needed .. broken boot spring lugs ... please
Aussie Bob
Post by Aussie Bob »
Hi everyone, has anyone got a remedy to the broken lugs on the boot spring? One half of the lug has been broken off on each side :(
oldnek
Re: Help needed .. broken boot spring lugs ... please
Post by oldnek »
Hi Steve, I pretty sure a guy on the FE/FC forum makes them. FCcool may know of him.
Aussie Bob
Thanks John, that would be amazing. I guess you just drill the old one out and melt the new one in.
Steve
hawk
Post by hawk »
Steve ,this what you need.
Regards ,Greg.
http://fefcholden.org.au/forum/index.ph ... 609.0.html
Aussie Bob
Thanks Greg, sent Ret a PM.
I appreciate your help.
Steve
Aussie Bob
Thanks to Greg and Ret, done all done ..... eight hours later .... :oops: I think I could do it in two hours now I know the right steps.
Step one ... grind the back off the broken lug almost flat to the support. ........ I drilled through from the inside for hours and used many drill bits. The drill spun out of my hands a few times :cry: Ouch! It took ages stepping up through the sizes and burning bits. I then went to Bunnings and purchased three very expensive dtill bits in high tensile. With a bit of cut compound on the tip, this worked well. After drilling, I found out the thread on the new spring bolt was not long enough :roll: :oops: So then I ground the back of the old Lug as per step one ... :D
Step two, drill the hole for the bolt to go through. The biggest drill bit I purchased was a 1/2" The thread needs a slightly bigger hole.
Then it is easy from there to adjust the spring tension with a long Hex Key and a 7/8 thin spanner. This is a great method as you don't need a spring tool and this avoids looking fingers.
I believe FE-FC original lugs are easier to remove.
Steve
Without nasco broom handle .....
Only problem now is you can't sell the car as original :( , may as-well put a red 6 or a V8 in it now :P :wink: .
Aussie Bob
The Bolts were NASCO I am told ;) and they didn't come from ebay!!! How rare is that :?:
:lol: :lol: :lol:
Steve Jackson wrote:The Bolts were NASCO I am told ;) and they didn't come from ebay!!! How rare is that :?:
:lol: :lol: :lol:
:shock: wow :lol:
Aussie Bob
Just spoke with John who made the Pins.
Get a flat Bar, drill a hole in it for snug fit, place it over the original pin and rock back and forwards, spot welds and pin should brake away. :oops: :oops: :oops:
John, you just saved me five hours work :lol: :lol: :lol:
Thanks so much,
Steve
oldnek
Post by oldnek »
There definitely the go, easy to fit and adjust.
Best of all there made in Australia. 8)
EKfanPaul
Post by EKfanPaul »
Just noticed this thread Steve,
i took out a whole boot upright piece, neatly ground off the forked end & welded in an original piece.
I had a mate in the FC club help me put the spring on as he had that fancy tool.
Paul K
Aussie Bob
oldnek wrote:There definitely the go, easy to fit and adjust.
Yes, a wonderful invention. Just got to make sure there is even tension on each spring.
Steve
Aussie Bob
EKfanPaul wrote:Just noticed this thread Steve,
Paul K
I remember you telling me Paul :D
You now know how to do the next one!
