Diff for 1 uzfe
Posted: Sun Feb 06, 2011 1:50 pm
by ek amigo
Hi I am researching what I need in the way of diffs for a toyota V8 auto setup in an EK sedan . What is the consensus of opinion out there?
Re: Diff for 1 uzfe
Posted: Sun Feb 06, 2011 8:23 pm
by Mick
drive steady and the banjo will be fine
if you want to play
borg warner or 9" both have there pluses and minuses
Re: Diff for 1 uzfe
Posted: Mon Feb 07, 2011 2:45 am
by Brodie
I thought about doing this conversion myself... Got the motor, box, bell housing etc sitting in the shed ready to go...
I wouldnt worry about a 9 inch unless you were going to stick a blower on it. The 1uz motors have more of a developing power curve and less low down torque so stresses on your drivetrain arent that great. I'd go with a Borg Warner, if your going to punish it go 4 pinion just to be on the safe side.
Re: Diff for 1 uzfe
Posted: Mon Feb 07, 2011 11:00 am
or keep the Jappa theme going and whack a Skyline or Hilux diff in it - theres a few over this way that have gone down that road.
Re: Diff for 1 uzfe
Posted: Mon Feb 07, 2011 12:58 pm
by Mick
hilux = limited ratios and for what they are are quite expensive aswell
Re: Diff for 1 uzfe
Posted: Mon Feb 07, 2011 3:14 pm
by Trev
I thought Hilux had lots of ratios.
Just did a serch and found these (and shit loads more), not all were available in Aussie cars thou.
RATIO TABLE
Ratio 01 3.300
02 3.360
03 3.545
04 3.556
05 3.700
06 3.889
07 3.900
08 4.110
Re: Diff for 1 uzfe
Posted: Mon Feb 07, 2011 5:29 pm
harry186 wrote:hilux = limited ratios and for what they are are quite expensive aswell
Hilux diffs are common as bums over here - and you dont need to narrow 'em
Re: Diff for 1 uzfe
Posted: Mon Feb 07, 2011 6:05 pm
by wot179
Mine cost a hundred bucks off ebay including standard wheels and handbrake cables.
Re: Diff for 1 uzfe
Posted: Mon Feb 07, 2011 10:00 pm
by Mick
ratios are all still quite close and good for drag racing type aplications if that's what you want, only going on stuff i've read re: not cheap over here
Re: Diff for 1 uzfe
Posted: Thu Feb 10, 2011 3:02 pm
by ek amigo
thanks for all that gents , well I have a good Hr so I might as well give it a try . I have some pics of my car but can't figure out how to put them on , any advice on that?
