Lug nut King on Ebay
Aussy Edo
Post by Aussy Edo »
Hey guys,ime after a set of bullet push throughs for my 14'' steelies,they are at the powdercoaters at the moment so cant get measurement of the diameter of the centre hole,is the centre hole the same size for both HK/HT or do they differ?also i was told i need the tapered lug nuts aswell in 7/16th,is this correct?,if some one has a HT/K wheel lying around can they measure it for me please,i think its about 80mm but want to be sure before i order in the next day or so,the item no for lug nuts is 110607278357,cant do the link thing,cheerz people
Edo :D :wink: :P
One Day Hopefully!!
Re: Lug nut King on Ebay
You need 7/16" thread on your wheel nuts , cant help you with the hole diameter though.
wot179
Post by wot179 »
Just measured a HK rim for ya--its between 62 and 63mm.
Cant give you closer than that coz I loaned my verniers to a buddy and Ive only got a tape measure handy.
Oh,and Im gettin old and blind....
Hope that helps.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
Aussy Edo
Post by Aussy Edo »
Thanx guys,much appreciated :D
Edo
One Day Hopefully!!
Aussy Edo
Post by Aussy Edo »
Hey guys,got rims back from powdercoaters,look pretty good,you were right WOT,i got the verniers out and the diameter of the centre hole is about 62.5mm,so i rung up lug nut king off ebay to see if they had push through bullets to fit but they have nothing smaller than 70mm,has any one here run push through bullet centre caps to suit hk/ht stockos,if so can ya give me the details of the shop you bought them from,cheerz Edo
One Day Hopefully!!
I once had push through caps but they came from a catering shop, they are called "dario molds", you can get them in stainless or alloy, and are flat on the ends not pointy.
BS
Post by BS »
Ive got bullet push throughs on my 14" HT steelies. Can't remember the ebay store but if you google "spun by hutty" that is the dude I bought them from.
