mild cam and alloy gear for a grey
20/60 ! any go fast bits for a grey ? thanks
Re: mild cam and alloy gear for a grey
How about a triple su manifold or a set ???
steel cam gear ??
somebody must have something !
steel cam gear ??
I know someone whom might want to part with a complete triple 1 1/4 SU and Lynx manifold setup, including linkages and fuel block. Won't be cheap though.fjuteman wrote:How about a triple su manifold or a set ???
steel cam gear ??
I've been doing a lot of research on grey motor cams lately. The best way to proceed is to get your stock cam reground. Waggott Cams and Wade Cams have quoted me $150 pp.
Go fast grey motor stuff is comming hard to come by. Nov 13th at Bendigo might well be worth a look. I have a set of tripple SU's but havnt seen them reasonably priced for a few years. Almost never see a hot head or cams but Wade will still grind a grey cam and alloy timing gears are still around and extractors can be found on ebay brand new.
How much do you want for the SUs ?
Fjuteman,
My mate will part with his triple grey motor SU setup for $650.
It consists of a Lynx manifold, three 1 1/4 inch SU carbs, all linkages and fuel block. Price reflects that carbs need rebuilding. The manifold also has the bolt holes should you want to install the larger 1 3/4 in SUs.
PM me if interested.
I saw a set at Bendigo for $490 1 1/4 they needed a bit of a cleanup though.
Nah, to expensive. Carbs can be picked up for about $50-$100 e@ that makes manifold about $300-500.
But thats just my opinion !
But they won't be a matched set and they'll need rebuilding too. Anyway, best of luck with it FJ. Professionally rebuilt multiple carby setups, either SU or Stromberg, are not cheap.fjuteman wrote:Carbs can be picked up for about $50-$100 e@...
You're mates need rebuilding so I'll be no worse off..............cya
