getting the old girl ready
hi guys gonna strip the wagon soon to paint but first i want do any mods that are needed , (1) its running a 179 so not sure whether the standard fb radiator will cope even with a thermo fan or should i go bigger i'd rather be safe than sorry, (2) im am currently running a smiths heater but the fan is very noisy how good are these heaters as i was thinking of buying a smaller after market heater , the wife likes to stay warm , can the fan be quietened .sorry if i sound like a dummy but i havent had the car registered since i bought it so i dont know how the old girl drives any help would be great. no dought i will have more questions later .thanks troy
Hey Troy,
Im in the same boat mate , just that im running a 202...i reckon the old radiators struggle keeping the reds cool but thats just my opinion...The solution is install a HR or HZ (3 core if you intend to work ur red later down the line) radiator.
Mate I run the beehive smiths heater so i know what you mean when you talk about the sound but i dont mind it and unfortunately I cant help you out with a substitute.
Good luck Mate .
robbo
p.s. whos painting your car??
Good luck Mate .
robbo
I had an FC wagon in the early 80's running a standard 161 and the original FC radiator which I took the tanks off and cleaned out the cores.Would run OK up to about 50 mph but would get too hot if you had it loaded up or exceeded 50 or so.Tried a cooler thermosat etc but no difference.Tried a higher pressure cap (13 psi I think??) also.Had the standard 3.89 diff but maybe would be a bit better if a 3.55 or 3.36 ratio was fitted.
Tried everything I could think of to fix the problem but I think the standard radiators cooling limit was reached with the 161( and my teenager driving practises
It was also fitted with the Smiths beehive heater and it heated very well and yes I know they are noisy but thats what the radio volume knob is for!!
I would turn on the heater to help cool the 161 when it was running hot...yes even in summer!!...and it would help to a small extent.
Terry.
Terry.
