Hi
ive got a small hole in the top of the fuel tank in the sedan
what can i use to plug it up untill i get time to take it out and repair it
or replace it is there a product i can get to put over the hole Jay
If you can find a 1or 2 cent coin you should be able to solder it over the hole if you are lucky two have it on a flat spot or you may have to bend it a bit to suit will be safe enough if tank is nearly empty done it heaps of times will last longer than you
BILLY
BILLY BLACKARROW
If its a small enough hole you could just solder it up and be done with it, otherwise as Mark said Knead it. I had a few holes too big to solder and that was what I used in mine. Works a treat!
Forgot to say use a soldering iron not a flame common sense I know ---- but
BILLY
BILLY BLACKARROW
