Engine Mounts
NoMAD
Engine Mounts
Post by NoMAD »
Was wondering if anybody had any pictures of where the engine mounts move to on a HD/HR Crossmember when fitting into an FB.
Trial Fitting the 186 Motor this weekend and sorting out where they need to go, if anyone has any pics or sketches with some dimensions on it that would be appriciated, just pm and i'll give you an email address or just post it up here.
NoMAD
ipg
Post by ipg »
http://www.fbekholden.com/forum/viewtopic.php?t=1190
check out the first and second pictures
Basically at the back, as per ipg's pics.
But if your trial fitting everything. Drop it all in then tack the mounts onto the crossmember once its all sitting where you want it to. That way you can gaurantee you have clearance where you need it.
