Restoring FB Dash Trim
Posted: Fri Jul 23, 2010 7:46 pm
by Thommo
Hi All
What is the best method for polishing up FB dash trim without removing the printed pattern?
This pic shows there current condition, they are better than the pic shows.
The print is clearly visable on all the pieces, its just the camera/flash angle
that makes them look more oxidized than they are.
Jeff
Re: Restoring FB Dash Trim
Posted: Fri Jul 23, 2010 9:02 pm
by EKjimmy
get em vapour blasted
that may be too rough, not sure though.
try toothpaste, or water and bicarb soda or something, then metal polish, then if that works give it a light wax just to keep it clean for longer
Posted: Fri Jul 23, 2010 10:10 pm
by minifb
I wouldnt try any of those.. I tried to clean one with a wet rag one day and it wiped the stars off. Tims idea sounds the go.. Cheers Mark
Posted: Fri Jul 23, 2010 10:51 pm
by Bigbird
The trims in the green FB that I own were slightly oxidised and there was "goop" on them, I remember the look on Craig's face when I took to them with Prepsol, but they came up nice and left the stars.
Posted: Fri Jul 23, 2010 11:01 pm
by minifb
SunnyTim wrote:Someone needs to spend a few days doing a lazer cut of the 3,000 stars and you could respray them......
HMMMM........... sounds good...
Posted: Sat Jul 24, 2010 10:48 am
by parisian62
I think most polishes will remove the stars...found that out when I was 18 and thought to myself at the time that they needed a cleanup
Posted: Sat Jul 24, 2010 11:08 am
by EKjimmy
i stand corrected. never had an FB, i'm too good for them
so are the stars painted on or something? i assumed they were stamped like the ek dash trim.
Posted: Sat Jul 24, 2010 1:22 pm
by minifb
Posted: Sat Jul 24, 2010 1:43 pm
by Bigbird
They were screen printed
Posted: Sat Jul 24, 2010 8:22 pm
by ben
Jeff, I found automotive finishing polish and your bare finger, is as hard as you can go before removing the print. Brings them up good, but frustratingly still leaves the pitting. I ended up throwing in EK trim
Posted: Sat Jul 24, 2010 9:32 pm
by Bigbird
In my other car (not a concorse original) I just polished the trims up till they were almost like mirrors to match the guage cluster.
Posted: Sun Jul 25, 2010 3:02 pm
by Thommo
Thanks fella's
I have one spare FB trim piece that I will try some of these ideas on.
Jeff
Posted: Fri Sep 17, 2010 8:45 pm
by artyfartymarty
thats not a bad idea
it could be made from sticky back masking film..hmmmm
