Hi All
What is the best method for polishing up FB dash trim without removing the printed pattern?
This pic shows there current condition, they are better than the pic shows.
The print is clearly visable on all the pieces, its just the camera/flash angle
that makes them look more oxidized than they are.
get em vapour blasted
that may be too rough, not sure though.
try toothpaste, or water and bicarb soda or something, then metal polish, then if that works give it a light wax just to keep it clean for longer
The trims in the green FB that I own were slightly oxidised and there was "goop" on them, I remember the look on Craig's face when I took to them with Prepsol, but they came up nice and left the stars.
i stand corrected. never had an FB, i'm too good for them
so are the stars painted on or something? i assumed they were stamped like the ek dash trim.
Jeff, I found automotive finishing polish and your bare finger, is as hard as you can go before removing the print. Brings them up good, but frustratingly still leaves the pitting. I ended up throwing in EK trim
