blue or black head on red 202
fb123
Post by fb123 »
g'day does anybodyknow if a blue or black head fits the red 202 motor.Has anyone put injection on a red if so what hassels did you have.Would appreciate any advice.Have the injection off a vk.
To fit a blue or black head to a red block you will need to muck around with the water holes . The best way to do it is to make a template of your new head with cardboard and then lay it over the block and see which holes line up and which holes need to be drilled/plugged.
To plug any holes not required the easiest way is to tap them out and get a grub screw with an allen head from coventrys or blackwoods, etc - use a good sealant on it and they will last forever.
HTH
Sammy
Post by Sammy »
heres a little webpage i wrote on the subject of blue/black head on red block.
http://www.oldholdens.com/tech/eficonversion/#head
the whole page details the requirements for putting VK EFI into old holdens of which head conversion is one section.
Regards,
Sammy.
fb123
blue or black head on 202
Post by fb123 »
thanks for the info and web site.Now has anyone put a blower on with injection and if so what hassles did you encounter.
Sammy
Post by Sammy »
i've heard if you put it on with VK EFI you need aftermarket computer, my plan (for an SC14 blower) is to fit VN computer to the VK EFI then i will be able to bolt the blower on and tune it no problems .... i haven't gotten too far yet though so i don't have alot of info, but if the blowers work on a stock vn v6 i shouldn't have any dramas other than some custom piping and brackets etc.
Regards,
Sammy.
ek61
Post by ek61 »
mate go with a blue or black motor from the start better internals
check out www.hotholdens.com
my mate steves ek van blown injected blue 400hp+ he will answer your questions
***just cruise***
fb123
blue or black head on red motor
Post by fb123 »
Thanks once again for the info.Would you need the computor from a vn already with a blower or do you reckon any vn computor would do.Just wondering wiyh a standard computor would it read a negative boost when in reality with the blower it would be possitive boost.if so would you need to trick it up to read positive.Look forward to any info.
mick
ek61
Post by ek61 »
just pm him some questions on the link i put up i dont want to give all his secrets away but i can tell ya its one hell of a ride in the old bus thats 4 sure
***just cruise***
