HR Front End, Sump?
erica
HR Front End, Sump?
Post by erica »
Hey guys i have a Red 202 in my Ek ute with just the standard front end. I have an HR front end all ready to go but wondering if i have to change the sump or will it be ok?
Post by mrs ratbox »
it should be fine if you have the red in there already, however unless it's already been done the engine mounts on the HR crossmember will need to be moved
erica
Post by erica »
Thanks Ratbox. There are no mounts on the HR front so i will weld on the current ones from the standard front end, which are already set back. Thanks
If you can leave the motor and box in and tack your mounts on that way you can gaurantee no little surpises.
