what guage steel for repairs
EKDan
Post by EKDan »
Hi, i am going to be cutting out a few spots of rust in the wagon where the fuel tank bolts in, and am trying to find out what thickness plate and where to get it from in the perth area.
i dont think a street sign will look right :)
thanks Dan
BANGOES ANOTHER DIFF
Hi Dan, use 1 mill cold rolled steel, easy to work with and thick enough for these old girls :D , Trev 8) .
I'm with Trev on this, Dan...
I have used it and it lends itself well to being ground back after welding.
I have been forced to use .6 mm with my little Jap car..... and it's a pain in the (you know) to weld using a MIG.
If you find yourself blowing through and can't get your settings any lower to weld with - try backing the joint with a brass or copper plate (scrap metal merchant)...
EKDan
Post by EKDan »
Thanks for the tips guys, its one of thoes jobs i've been putting off
but i will get it done this weekend!!
careyman
sheet metal
Post by careyman »
I was going to go to a wreckers and ask for a roof section or maybe a boot skin from an old car, would this b suitable for banging around
(sry to hijack ur post ekdan, ive got soo many questions)
cheers :wink:
FB's=Friggin Bewdyful
careyman, I wold be careful using old panels for repairs, if the already have some corrosion the thickness can vary making it harder to weld.
I got a huge sheet of 1 mm steel for about $40, can't go wrong :wink: , Trev 8) .
FB1960
Post by FB1960 »
Try
Elldon Metal Industries
308 Victoria Rd, WA, 6062
p: (08) 9249 9668
Marty
Going nowhere, getting there fast
I wnet to a steel shop and bought panel steel. $25 for half a sheet can't go wrong!
oldnek
Post by oldnek »
I would rather use Zincanneal sheet, you can weld it pretty easy, stronger than mild steel panel in the same thickness, and doesn't rust........
DOLLER
Re: what guage steel for repairs
Post by DOLLER »
What about plate for a floor pan????
Ed
Post by Ed »
I use 1.0mm zincanneal.
for the floor plan, you may need to put swage lines in it for strength?
i've alwalys patched floors with zincanneal, but if it's an entire section I will buy a repro for the matching lines.
Ed
FE/FC Holden Car Club of NSW
wot179
Post by wot179 »
Cold rolled lends itself to being dollied up into curves or complex shapes a whole lot better than zincaneal.
Zinc aneal is a lot harder.
For floor sections,1mm will do the job fine,but Id personally be leaning towards 1.2mm,or even 1.6 for something like a
fabricated Trans tunnel (not that you will be doing this....but I'm on a roll....)
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
Ed
Post by Ed »
Good info Wot179, will try some out on my next purchase.
I actually need to do a trans tunnel soon.
DOLLER
Post by DOLLER »
Thanks guys. I'll probably go the 1.6mm to patch a couple sections of the floor. They are fairly flat so it should be easy-ish.
DOLLER
Post by DOLLER »
Is it ok to use Gal sheet?
