Moderators: reidy , Blacky
Posts: 2480 Joined: Thu Apr 18, 2019 4:14 am
Post
by Brett027 » Fri Sep 10, 2021 1:40 pm
Thanks Clint. Cut and hole ready to join up
Posts: 11420 Joined: Sat Dec 06, 2014 2:44 pm
Post
by Errol62 » Fri Sep 10, 2021 1:47 pm
I feel better already Brett.
Orange Betty
Posts: 150 Joined: Wed May 30, 2018 4:46 pm
Post
by Orange Betty » Fri Sep 10, 2021 2:52 pm
Is that weld thru copper primer you use Brett?
How do you find it goes with welding?
Dave
62 EK Sedan in slow progress
Post
by Brett027 » Fri Sep 10, 2021 3:27 pm
Yes it is. No problems at all Dave. Much better than the zinc ones for my welds.
Post
by Brett027 » Fri Sep 10, 2021 3:30 pm
This ones for you Clay. Nearly finished.
Will try a bit of lead wiping on the windscreen pillar when the time comes to level it. There is a dip in the front section at the join, but sides are good.
Brett027 on Sat Sep 11, 2021 3:19 pm, edited 1 time in total.
Post
by Errol62 » Fri Sep 10, 2021 3:30 pm
Thanks for posting Brett. Copper seems popular lately. I will give it a try, when I eventually get back to the van.
Post
by Errol62 » Fri Sep 10, 2021 3:34 pm
Hadn’t seen your second photo. Text book job Brett! Looking at that l feel good enough to go surfing.
Post
by Brett027 » Sat Sep 11, 2021 3:16 pm
A hole and a patch.
Posts: 1196 Joined: Thu Jan 19, 2017 9:57 am
Post
by ardiesse » Sat Sep 11, 2021 5:59 pm
The joys of repairing plenum chambers . . . I remember doing that on an HD in '98.
With 20/20 hindsight, it would have been way better to unpick the cowl panel complete, and dive in that way. But at the time, drilling spot welds was black magic to me.
(Edit: do you have a windscreen for trial-fitting? Now would be a good time to test the fit . . .)
Post
by Brett027 » Sun Sep 12, 2021 12:42 pm
Drainage works.
I aim to seal it all with POR15 and seam sealer. Then tack outer cover back on. Very fiddly, but good task for a lazy Sunday.
Post
by Brett027 » Tue Sep 14, 2021 2:55 pm
Nearly sorted. A couple of patches to go. Some welding to do under the curve of the upper door part of pillar once it's on the rotisserie, but mostly done.
Very, very fiddly job- glad it's almost behind me.
Post
by Errol62 » Tue Sep 14, 2021 5:16 pm
Nice work Brett!
Post
by Brett027 » Tue Sep 14, 2021 5:42 pm
Thank you sir.
Posts: 2635 Joined: Thu Mar 16, 2006 9:51 pm
Post
by EK283 » Tue Sep 14, 2021 7:21 pm
What rust ????
Post
by Brett027 » Tue Sep 14, 2021 7:26 pm
Ha ha Greg, all I can say is "should've gone to Specsavers"
