Shed find ute
Re: Shed find ute
The blokes at Burt Brothers were discussing similar Wilwood masters with me the other day. They reckon no booster needed either, as the master puts out some incredible pressure with little pedal effort. I assume they have a small piston diameter to get the pressure, long pushrod travel to deliver the same volume to the caliper and a rejigged pedal geometry to get the same pedal travel for the increased pushrod travel.
Re: Shed find ute
Gledge on here runs no booster on his FB sedan with full house red motor.
- WesternWagon
- State: WA
Shed find ute
Bit of inspiration from the spanned day
Tidying up the last few rust repairs needs final sand a tap
Install remaining seatbelt and satin clear the dash then fit windscreen and roof lining
Member : Holden Car Club WA.
:ASRF Member
:ASRF Member
Re: Shed find ute
Nice work Gazza
Re: Shed find ute
Those bottom guard corners are not even close hey ....
Re: Shed find ute
Well done mate.
- WesternWagon
- State: WA
Re: Shed find ute
Yes mate needed some massagingBlacky wrote:Those bottom guard corners are not even close hey ....
:ASRF Member
:ASRF Member
- WesternWagon
- State: WA
Re: Shed find ute
Agree mate, required some hammer love to fitWesternWagon wrote:Yes mate needed some massagingBlacky wrote:Those bottom guard corners are not even close hey ....
:ASRF Member
:ASRF Member
- WesternWagon
- State: WA
Re: Shed find ute
Door rubbers bailey channels and freshen the 1/4 vents
Old rubbers very crusty paint work in very good nick
:ASRF Member
:ASRF Member
Re: Shed find ute
Looking good!
Sent from my SM-N960F using Tapatalk
- WesternWagon
- State: WA
Re: Shed find ute
One door down, one to go
Then off for glass and roof lining
Dang those 1/4 vent rubbers are fun
:ASRF Member
:ASRF Member
Re: Shed find ute
Fiddly job Gazza but you won’t miss the whistle. Good to see you progressing this mate.
- WesternWagon
- State: WA
Re: Shed find ute
Bit of a trim for the radiator, could squeezed it in but don’t want it to rub
Will blend some 1/4 plate into the subframe for the lower mounts
I love this little body saw, 1/4 hole and off you go, little linishing grinders are handy also
:ASRF Member
:ASRF Member
- funkyscooter
- State: NSW
Re: Shed find ute
My tight arse tip with the powerfile/grinder. Buy normal belt sander belts and cut them to size with a Stanley knife. I’ve cut some as small as 10mm to get into tight spaces.
Scott
Scott
Scott
Re: Shed find ute
More on this please Gazza
