hi all i am fitting a HR front end to my FB can someone tell me which is the best model outrigger to fit with a red motor any help would be appreciated
As far as I'm aware FE to EJ. EH should fit also but will be missing the two bolt holes but you won't need the two bolt holes since you are using a red anyway.
EH is best one to fit as the grey motor outriggers are to shallow as the hr crossmember is deeper in the channel if you get my drift. You can a use grey one but you will need to cut some wedge shaped pieces of steel and do a cut n shut on it so it reaches top and bottom. Easier to make one from scratch out of folded sheet i reckon.
Mines the same as ek61's. EK outrigger on hr crossmember. Replace the hr one with the ek outrigger and it bolts up without any drama. Rares also sell a rubber kit to suit hr crossmember into earlier holdens.
Devilrod wrote:Mines the same as ek61's. EK outrigger on hr crossmember. Replace the hr one with the ek outrigger and it bolts up without any drama. Rares also sell a rubber kit to suit hr crossmember into earlier holdens.
Yep, if you are after the rubber kit its order number is:-
FEK4A Kit Front End Mounting Rubber FE-EK With HR X Member
Try Classic Oz Wreck in Newcastle NSW , haven't got the phone number handy but it should be in yellow or white pages online.His prices however are a bit on the high side though??
there's been repro ones on ebay lately failing that i can get one, would need to be paid for the hassle of pulling it off and postage and wouldn't even be able to think about pulling it off before next monday or tuesday
Max, PM V8EK4us on this forum, he is a Darwinite and has a few modded cars, so i'm sure he would have stock outrigger!
Cheers Theo Z.......................
