EK suspension
EKjimmy
EK suspension
Post by EKjimmy »
I realise i have already had a reply from Blacky advising me to get my springs reconditioned, but with all respect mate i dont think it's possible for me to go down that road with my springs.
Three questions:
1. Other than specialists who make springs to order (made to order=$$$) does anyone know where to get leaf springs for EK's and any other old holdens for that matter? I need either ones in good condition, or new.
2. Does anyone know if EJ, EH, HD, or HR rear leafs can be fitted to an EK sedan without modifications of mounting points.
3. Failing that, are there any other springs from other cars eg. something like a light van or similar that just happen to be the right lenght and width for the job?
Any Info appreciated as always. Cheers Jimmy
lunatic leprechaun
SPRINGS
Post by lunatic leprechaun »
mate,
take blackys advise. take your car into a spring place and they can give you there professional opinion and which paths to take, and will probably have the same sources as repco. they can add leafs, lower or heighten your ride to your desired height. and cheaper than buying a name....
jim
thropzed
Post by thropzed »
Hey Jimmy, A quick google and this is what comes up. I assume your in Baulkham Hills and this joint is preety close. Check them out.
http://www.carrolls.com.au/
Cheers Theo Z.............................
FB/EK Car Club of QLD.
EKjimmy
Jim and Theo Z
Post by EKjimmy »
Thanks for the replys fellas, took your advice on board and will call up Carrolls (cheers for that link Theo). Eventually i'll broaden my knowledge and be able to supply it to the next generation of old holden lovers!
thanks again, jimmy
yeprat1
Post by yeprat1 »
yeh mate give better springs a call thats their specialty they can fix yours or they can make u a new set they are very good located in st marys, cheers troy
dave68
State: QLD
Post by dave68 »
I used liverpool suspension they worked out all right for manufator but don't fit it up. They use a guy around the corner for that. :wink:
Whatever....:(
EKjimmy
Post by EKjimmy »
thanks for that guys, i'll give those places a call
