What sender to use for Falcon fuel tank
EKWagon
Post by EKWagon »
Adding a Falcon fuel tank to the EK and was wonderign (for those that have done this conversion) what sender do you use? the original &*#@ one or is there something else that works with the original EK guage?
EKWagon
ekdave1962
Post by ekdave1962 »
hey check with mal he fitter a xb tank to his beast ..but he also used after market guages
J
Post by J »
ask nomad
NoMAD
Post by NoMAD »
He did, in a pm I replied but it doesn't look like he's opened it... I have down it yet but I'm planning on using the xb sender, and if the normal gauge doesn't work then making 1 out of the xb mixed with fb or going aftermarket and doing the same thing so it still looks original...
One of those push down the list items!
NoMAD
EKWagon
Post by EKWagon »
Thanks guys, I will give the XB one a try
I have a few of the adjustable resistance guages here will try it with them and see if I can get it to work
EKWagon
NoMAD
Post by NoMAD »
oh memory the resitance on the FB ones are 0-30ohmsand i think the XB are 73-10. (75-10?)
i was going to look into getting a 75-10 aftermarket 2 1/8" fuel gauge and fitting it into the FB housing to use the face plate and the needle... or kustom gauges from somewhere like classic instruments or probably mooneyes!
NoMAD
