Grey motor problems
FB Cruiser
Grey motor problems
I need help with the grey in my FB, Ive changed the coil, pionts, condenser and had the carby done. She runs great around town but when I drive her to work I get about 20k's from home, all highway driving, and she starts to miss and lose power.
Come home redo everything and she runs great again, drive her to work and almost to the dot, 20k's from home she stars to miss and lose power, this time I had to be towed home. Im at my wits end as its coming into good weather and I cant get out in the old girl ,but I cant work this one out. Any help would be great, Cheers Pat
Re: Grey motor problems
Gday PatFB Cruiser wrote:Come home redo everything and she runs great again,
What is it that you redo?
If its more than one thing,
try doing just one 'redo' and see if that makes a differance.
If not, try one other thing, and test again.
We need to narrow down what the problem is.
Jeff
FB Cruiser
Thanks all, well I have tried reseting points and timing, then had float level set so all good. Carby is spot on so Im back to coil. Have changed the coil with 3 different ones and all seem to run fine. Im starting to think that the fuel pump may be on its way out. Its a red motor pump so I'll pull it of the car and have a look. Any more ideas would really help. cheers Pat
fc visitor
FB Cruiser
G'day Rosco, the miss seems to be by location(travel the same way to work every day). Using this trip as a bench mark as all the good rod runs and cruises are at leest 50 k's or more from home. fc visitor I will look at the fuel pump hopefully before the weekend. Thanks for the advice guys this site is great for help. Keep it up guys, cheers Pat
Ok - then is it at a particularly steep or acute angled part of your trip - which does not occur elsewhere.... I'm merely suggesting here - and this may not be the case.... that your fuel pump may be struggling to supply fuel from the tank due to the demand on it to pump it up ...... it's probably not the case.... but it is one chance..... also - although you have checked the fuel level and needle/seat - it could be that the carby is starving on a particular angle......
need more info.....
need more info.....
fb cruisin
FB Cruiser
FB Cruiser
FB Cruiser
Well guys, I just rebuilt the fuel pump on the old girl and and fired her up, sounds good
. I let her warm up and took her for a drive, feels good
. Keep on driving and bang theres that miss and cough, keep on driving at 60 mph and it gets worse. Im pulling my hair out, its driving me crazy. Carbys good, fuel pump is good, spark is good, now Im out of idea's. Any ideas would really help guys, cheers Pat
FB Cruiser
