stuff on inside of roof
Post by mrs ratbox »
on the inside of the roof there's a tary cardboardy type stuff is this just an insulator it's not there anymore on mine 1. do i really need it 2. what is something i can use instead
It is there to stop the roof drumming Ratbox, I wouldn't remove it but if its buggered I dont know what to replace it with - no doubt Dynamat would have a product available but it wouldn't be cheap.
don't have a choice it's already gone :shock:
ek wazza
roof sheeting
Post by ek wazza »
you can buy sound deadener sheets from panelshop supply companies that you can cut out and stick on whatever shape you like. they are used alot for newer vehicles on boot floors and spare wheel wells.
Building an EK Special Sedan 304 T700, Rodtech F/end with disc's front & rear, and driving an EK Special Sedan Grey with Trimatic and the rest stock
Finny
State: QLD
Post by Finny »
I had a small section missing.
I reattached the areas that had dropped down using contact adhesive.
But I also had a small section missing.
I thought I would grab some from the parts car to re-use.
Unfortunately it was badly eroded and fell apart as I removed it.
Then going to use some from a parts commodore roof.
It had similar insulation to floor insulation.
But it had already been taken. This is what it should have looked like.
Probably end up using dynamat.
Theres a bloke at the hotrod show selling dynamat - 36 square feet - about enough for a roof and a bit - $275 :shock: and thats a show special price , normally $325 :shock: :shock: :shock:
FB MAD
Post by FB MAD »
:roll: Sheet :roll: , think I'll pull a few pink batts outta the roof of my house and glue them in !! :lol: :lol: :lol:
blue ute
Post by blue ute »
Be a bit carefull as there is only a small gap between the bow centre & the roof line (almost on the roof), remembering the original insulation was only approx 3mm thick.
fb cruzn
Post by fb cruzn »
A guy i knew used the silver and blue stuff thats used on houses, sizealation (spelt wrong) is what its called i think, if its not used at all the condensation would wet and stain the roof lining
EK DAZ
Post by EK DAZ »
I pulled mine out of my wagon because there was quite a bit of surface rust between the roof and the cardboard type stuff.Also because the cardboard stuff went above the steel hood bows, I ended up drilling the spot welds out of the two hoodbows on one side so I could get above them.I will have to tack weld these back in later.
EK DAZ
