xu1 motor ( what size stall converter)
minifb
Post by minifb »
Hi All, Im in the process of buying a 202 that has been built to xu1 spec's. I want to Know what would be the best size stall converter to put in it(trimatic). It will be used as a everydayer(The Pig) There will be no hooning in it unless im driving it lol. Cheers Mark
FB/EKForum member 123
Go and get a 4 cylinder commodore one, they are smaller than 6 cyl and will stall up more (cheep), Trev 8) .
FB MAD
Post by FB MAD »
Or a trimatic Gemini one.
minifb
Post by minifb »
Will they bolt straight up??
Post by mrs ratbox »
yes
FATBOY
Post by FATBOY »
what about a vk efi one ive got one and its cheap mini they have a higher stall then the others
regards fatboy
minifb
Post by minifb »
Thank you.
oldnek
Post by oldnek »
Sorry Mini, can't tell you, never been down the 6 cyl Auto path before.
But I would say the previous blokes know what there on about....
Diff gears and tyre height will have an affect too Mark. My old FC originally had a 3000rpm stall with an xu-1 ish specced motor and personally I think it needed to be about 3500. I did change the diff gears but it only made it more apparent it needed a higher stall.
