keiths fb ute
vintageholden
Post by vintageholden »
trim 608 834
paint 685 9692
body fb2106 2666
hope that helps
Aussie Bob
Post by Aussie Bob »
Thanks VH
Colleen Green ! :oops:
Steve
Post by mrs ratbox »
Steve Jackson wrote:Thanks VH
Steve
:lol: :lol: :lol: you don't know how close i was to saying it's colleen green just being a smart rrrss only cause that's the only light green name i know :lol:
minifb
Post by minifb »
I was going to say FB Green....lol
FB/EKForum member 123
Aussie Bob
Was that you first girlfriends name Mick?
vintageholden
FB-FC BONNET CHROME MAKE YOUR CAR SHINE
Item number: 180377859878
just won this for the ute
EBAY
Aussie Bob
Good work VH. You may already know, that you could need inner bonnet hinge springs once the Bird is fitted.
vintageholden
WHAT THE ????
FB MAD
Post by FB MAD »
If you don't have inner bonnet hinge springs inside the standard bonnet springs the extra weight of the bonnet bird can make the bonnet fall on your head sometimes.
Unless of course you have one of those very rare genuine NASCO Bonnet Holderupperers that I had on display at Bendigo Nationals!! :wink: :wink: :wink: :lol: :lol: :lol:
NoMAD
Post by NoMAD »
FB MAD wrote:If you don't have inner bonnet hinge springs inside the standard bonnet springs the extra weight of the bonnet bird can make the bonnet fall on your head sometimes.
as seen in your avatar!
cheers
NoMAD
FB MAD
Post by FB MAD »
Yep, thats it,someone had a closeup pic of it at Yamba nationals and put it on the forum here somewhere :? ??.
blue ute
Post by blue ute »
If the extra weight of the bonnet bird makes the bonnet drop - use a trampoline spring - fits perfectly inside the original spring.
vintageholden
got the ute going today
bought it not running
plugs ,points, leads ,dizzy etc
dot the fuel pump working..recond the carby.
ran for 10 mins
smoke came from dizzy and car stopped and wont start??????
any ideas???????
coil and points hot to touch
ekv862
Post by ekv862 »
May hav wrong coil :shock: I would try another one and re do points as they are probably burned. And see how you go.
Cheers Rod,
ALWAYS HAVE TO FINISH WHAT YOU START.
vintageholden
thanks i,ll try that
i,m using bosch GT40............??????
