Changing my Engine
J
Changing my Engine
Post by J »
Yep so I wanna put in the 202, my grey is running a bit dodgy
I am considering putting in a manual gear box, I wanna be able to have some fun in it, squeak my tyres etc so Im looking for more power.
So yes I will have to take the engine out,
1.will the red sit on the same mounts as the grey?
2.will I be able to use the same accelerator linkages?
3.change the brake pedal,
4.add a clutch pedal,
5.can i take pedal assembly out of a torana or something?
6.cut a hole in the floor for the shifter,
7.or could I somehow put it in the column? (wanna keep it original looking)
8.can i use the same wiring etc?
9.can i still use the same drive shaft?
10.can i use craig's old recored grey radiator?
Andrew put a new engine in one of his rides, it was bigger and he just called up and said he wanted to change the engine number. I dont wanna go to the pits so I think I will just do that. If not just run it in there illegally and paint it grey or somethin 8-)
If someone could please answer those questions it'd be awesome!
cheers
Jay
Craig
Re: Changing my Engine
Post by Craig »
J wrote:Yep so I wanna put in the 202, my grey is running a bit dodgy
cheers
Jay
hi mate
1 No new mounts are needed
2 with a bit of work
3&4&5 get the manual brake pedal and a cluch pedal from a manual car FB EK
6&7 cut a hole ore use a manual colum and linkages that you get the pedals from (if you you were in brivegas we could have swapped)
8 blinkers and horn shold just plug in you will have bridge the neutral safety swith
9 if you use a FX to EK 3 speed in the original position you can use a manual tail shaft however if you are putting in the red upgrade the box aswell
10 If it is in good nick it might be OK
If you dont get it approved and you have an accident and it is discovered you have a larger engin in it your insurance will not cover you if you dont have intentions of doing it leagaly be carfull with putting it on a public forum
Im shur you will get heaps more input from those with more knowlege but I hope this helps
Better dead than red
EK, the VN of the 60s
cameradoctor
Post by cameradoctor »
J wrote: I dont wanna go to the pits so I think I will just do that. If not just run it in there illegally and paint it grey or somethin 8-)
Correct me if I'm wrong but the distro on the grey is at the rear, whereas the Red is in the middle - an astute insurance accessor may spot this if the worst happens - best to get it all legal I reckon.
FB MAD
Post by FB MAD »
Yep, be carefull about mentioning illegal modifications on a public forum.
I am told by a person that would definatley know, that there are people in some law enforcement/registration authority and/or insurance companies that do peruse forums and are employed to do so to gather certain information from them.
I'll leave it at that.
(AUST)Mod
Post by (AUST)Mod »
Sorry J I must have been unclear on the phone. I have never done an engine swap. What I meant to communicate to you is that our FB and EK are both running reds, and the people at the pits didn't require and engineering guff for them when we presented them for inspection. I was thinking of this form when telling you that all you needed to do was phone them up and tell them of your engine swap:
http://www.dpi.wa.gov.au/mediaFiles/lic ... EngNum.pdf
And a few real life Western Australian cases here:
http://www.perth4x4.net/forum/showthread.php?t=25043
t950cat
Post by t950cat »
Wouldn,t you need to change to a disc brake frontend for a 202 (if not already done that is) and then you would need a eng cert?well in nsw you would i,d say. :?: :?: :?:
Tony
Stand and listen to knowledge turn your back on stupidity.......
(AUST)Mod
Post by (AUST)Mod »
He already has discs, regardless in WA you don't need a disc front end. That is MY personal experience with 2 cars (161 and 186). 202 could be different but I doubt it.
Nekro63
Post by Nekro63 »
Can anyone in Vic confirm if you need discs with a 202!?!?!?
Also do you have to do anything to either tailshaft??
ipg
Post by ipg »
guarantee u need discs in vic
will also need 2 speed wipers, chassis kit and seat belts, demister is probably also required...
t950cat
Post by t950cat »
All those hassles that is why i am going with the trusty 138. :) :) :)
Finny
State: QLD
Post by Finny »
J, typed up a long reply a few days ago, but it crashed in the upload, and I couldn't do it again. :cry: :cry:
Simple version.... 3 options in order. (My opinion) :roll: :roll:
Buy another car that already has it done. Simple, easy and quick. :D :D :D :D :D
Fix the grey, nothing new to worry about, or legal spec changes. :D :D :D
Get the Red and be ready for the many and various changes that will be needed to get it right. :D (Be prepared to be without the car for a while) :shock:
CHOPPED
Post by CHOPPED »
hey j did you get my pm about the clutch pedal :?:
HEY IT WASNT ME
J
Post by J »
CHOPPED wrote:hey j did you get my pm about the clutch pedal :?:
sorry mate i thought i replied :?: :?
il be keeping the EK an auto, just want it to be a cruiser - thanks anyway 8) 8)
