Time for another update.
The painting has come to a stop due to cold weather. The body is finished on the inside and the outside has two coats. (Except for the trim).
So this weekend we refitted the motor.
A new clutch assembly was fitted to the motor and then the gearbox was attached.
The tappet cover was replaced with an old one to avoid scratching the paint from the chain.
The only problem encountered in the process was that the new clutch hose turned out to be a back brake hose
However that did not matter that much as the uni joints have not been fitted to the drive shaft,
nor the radiator re-cored or new exhaust ordered. So a test drive was not on the agenda.
We fitted some of the old exhaust, small piece of the front pipe and a muffler, the old leaking radiator,
short piece of garden hose and a funnel as a fuel tank.
Connected the negative lead to the motor and positive lead to the starter motor.
Removed the plugs and cranked it for a good minute or two to get the oil up.
We then replaced the plugs, filled the funnel with fuel, cranked her some more, ran a wire from the battery positive to the coil, dumped a capful of fuel down the carby, crossed fingers and toes and hit the crank again.
Two spins and off she went……….what a great feeling to see and hear her running especially as she had been rebuilt last September and sitting on the stand since.
The static timming was spot on and no adjustment of the dizzy was needed.
I was informed that the alloy timing gears create extra noise, however this does not seem to be the case in this motor.
We ran her for around half an hour constantly varying the revs whilst she warmed up to avoid glazing the bore.
My main concern was the tappet adjustment, they were set to specs cold. I have read that they need to be adjusted hot, however as there is no excessive tappet noise so I will not have to play with them whilst the motor is running and therefore avoid an oil slick in the engine bay.
The only problem encountered is a fuel leak from the fuel bowl gasket – the only part, exept the coil that is not reconditioned (it was OK back in 2003
) – that will teach me not to take short cuts. I will order a rebuild kit this week and do the job properly.
We were very happy with the weekends results and retired with a stubby or two
