fuel sender
mez
fuel sender
Post by mez »
i was looking on the net and found this fuel sender
out of a 54 chev sedan i looked just like a early holden
one so i got it from the states $39 the bolt pattern fits perfect
it fits in the tank and moves the gauge when hooked up
(even seem to read correct)do all you guys know of this
(and not let me in on it)as in australia ive found it near impossible to find one
carpe dero
ek61
Post by ek61 »
great score 8) if it fits n does the job its got to be good :D
were there more available or just the one?
cheers dave 8)
***just cruise***
mez
Post by mez »
ek61 dime a dozen on usa ebay
carpe dero
MINT62
Post by MINT62 »
great advice mez :wink:
i eventually scored an original sender and had it recoed
theres a lot of U.S GM gear that looks like it would suit fb/eks
cheers for that
INVEST IN PRECIOUS METAL
How accurate is it Mez? You might have just solved one of those little dramas that plagues virtually every rebuild !
blue ute
Post by blue ute »
This is a good site for a lot of stuff that could be usefull
http://www.fillingstation.com
Have bought a bit of gear for my `64 off the Filling Station -good people to deal with and they post with USPS so the freight is reasonable.
Dave
Post by Dave »
I got one from the states that bolted straight up but the float arm had to be a lot shorter than shown in your picture to fit in the tank.
Can you post a close up of the bolted up end so I can see if it is vertical or horizontal design. The one I got was vertical and that was the problem.
My Band.....
www.myspace.com/thesuperdextas
To the best of my knowledge GMH used a bit of mid fifties Chev stuff. Have a look at the speedo in a 53 Chev, near identical to an FC, same with all the handles. So I'm not surprised that it works Mez. Just never thought to go down that route. Good stuff!
mez
Post by mez »
hey dave im in melbourne at the moment but i will when i get home the sender from what i know is a top tank mounted sender like a fb/ek
carpe dero
Hey Mez, you should have organized a catch up! How much longer are you down here? Oh yeah which part of Melbourne are you in?
Dave
Post by Dave »
sounds good if its top mounted it should be right as long as its 0-30 ohms.
Would be easy to adjust if its not reading right too being top mounted.
How can I get one? Mine is sorting of working but its very touchy having such a short float arm, it fluctuates a lot.
My Band.....
mez
Post by mez »
dave it is a 30 ohm one
just look on the usa ebay there will be few on there
carpe dero
Malcolm
fuel sender
Post by Malcolm »
Does anyone know where I can get a sender to fit my XB thank that will be compatible with the FB dash guage???
Malcolm W.
Probably easier to get another fuel guage,take it to an instrument maker and have it rewound to suit the sender Malcolm.
