ek front subframe
ek front subframe
dudeths,
i need a ek front subframe
it needs to be in melb so i can pick it up
i got burned by some pissant off ebay and after paying $100 dollars, the thing never arrived!!!
dog legs can be rooted
i dont need a cross member
cheers
ipg
cheers
ipg
I have one but its in my caripg wrote:cmon,
someone must have a subframe
othwise i will have to take a trip to the country with some tools...
Seriously though have you thought about sourcing a parts car? I did this, but be careful that the bits you need aren't worse than what you have. The subframe in the one I stripped was so badly rusted that the bottom sections were bowing!
Hello,
I have a really good front subframe with no rust, has been cut out and repaired though.(front lower tie member and one of the legs, I can't remember which one) The battery tray is the original and has rust pitting, it has been coated in a rust preventative sealant paint and won't be seen when the battery is fitted. I bought it for the restoration of an FB.
The first catch is that I am in Sydney, it is too big to post (obviously) however if you are interested I am sure one of the transport companies will take it. It takes two people to lift it comfortably.
Second catch is that it was originally off an EK, so I swapped the chassis number over (doh, you want an EK one) to the one off my FB.
It is fully painted in low gloss GMH black but I wrote the exterior paint colour in crayon under the paint on the passenger side of the radiator as per original. This could be stripped off and redone.
I would like to sell it to make some room in the garage. It is a big lump to have sitting around with no further use.
thanks.
thanks.
Hi Patrick,
I live in the southern suburbs of Sydney, it is a bit more than a coupla
hours away from Wagga Wagga though! Last time I drove there in my SS
ute (and in a hurry) it took 4 hours and that definitely was not on the
speed limit (no cops reading here I hope!) I paid $100 for it before
repairing and painting, so you can have it for that. Let me know if you are
still interested and when/if you still plan on visiting.
Thanks,
Troy
Thanks,
Troy
ok, so i went to sydney, but because it ws so far after i was meant to (big apologies to all involved) i totally forgot about this.
...so again, if anyone has a subframe that has stuffed doglegs i will take it, name a price,
devilrod if you still have that bowed one???
anybody within 2 hours of melb will be fine, not that im picky at all
cheers
patrick
cheers
patrick
i have 1 hear if you want it its yours
has slight accident damage on the front right side but nothin that cant be fixed and slight rust that can be fixed aswell i was going to use them on my ek but used another set
i will post pics tomorra night of the rust and damage
you pay postage and ill do the best at this end to get them to a transport company
cheers dave
cheers dave
***just cruise***
***just cruise***
