Extractor Fit on grey
nate_138
Post by nate_138 »
So i have fitted some extractors to the grey in my ej and having all sorts off clearence problems with the linkages hitting the extrators.
Anyone make some sort of linkage that worked for them or have any ideas?
Any info would be greatly app!
Sigs
Post by Sigs »
Hi Nate,
funny you posted this, i put some on my ute this afternoon and came across the same problem.
So far I have just rebent the linkage so that the arm which bolts onto the toggle rod which extends from the accelerator pedal is shorter in width thereby clearing the extractor pipes.
Probably not the most proffesional way to do it but it seems to work ok.
cheers,
Mat
mmm, maybe one day :roll:
nate_138
Post by nate_138 »
The problem i seem to be facing with mine is i have an auto with the kickdown is driving me nuts!!! otherwise it would be a simple link to the carbie!
nate_138
Post by nate_138 »
over it goin back to standard exhaust manifold if anyone has a spair would be great!
rosco
Post by rosco »
Hi Nate and Sigs,
I fitted ex's to mine when it had both greys in it and didn't have any issues..........looking at the rear pipe - I think mine may have been closer in towards the block........... too long ago - sorry......
Someone will undoubtedly come onto this and suggest a cable throttle.....
karsten
Post by karsten »
hey nate im sort of seeing this problem to i am assumeing your a hyrdo as well ,,, may have to cut and exstend rod also kick down anchors to exaust manifold which i had to split from intake manifold and left me with out the kick down anchor ,,but a bracket is easy to make ,, and im puting a twin carb manifold on which does luckely have drillings for that anchor,,,,another idea may be a cable set up,,, also i may have a original manifold for you will have a look,,, and let you know
Craig
Post by Craig »
Nate I have a standard manifold you are welcome to send me a PM
Better dead than red
EK, the VN of the 60s
