Red Rattler Revamp
Re: Red Rattler Revamp
Jeez that were quick
Errol62 wrote: Tue Jan 18, 2022 6:14 pm Jeez that were quick
Damn straight - I ordered them this morning around 9 and they were delivered about 1:30 :thumbsup:
Got a couple of little jobs knocked over tonight, one of our club members was having trouble with selecting gears in his FB so I went over for a look , found some adjustment issues and some flogged out selector rods and linkages on the gearbox so I took them off , bought them home and gave them a birthday
Did a bit on the rattler and the VS as well , the drop spindles I have had for years are finally making their way onto a car, but of course they don’t fit ImageImage
I shouldn’t be surprised I guess …. What kind of a moron designs a spindle with 2 mounting positions but only one of them can be used ???? ImageImageImageImageImage
Fixed it with my trusty hand held milling machine Image
Blacky wrote: Thu Jan 20, 2022 12:43 am Did a bit on the rattler and the VS as well , the drop spindles I have had for years are finally making their way onto a car, but of course they don’t fit ImageImage
i've fitted probably a dozen sets of dropped stubs never had an issue
You must have had the steering arms on the bottom hole every time, or HQ short arms are a different shape to all the other ones…
Got the front end pretty much all buttoned up , just waiting on a couple of bits - lower ball joints and brake pads . Painted the steering arms and caliper brackets and finished off the sway bar links.
FJWALLY
Post by FJWALLY »
Blacky wrote:Image
Looking good Blacky - that tie rod end looks to be at a weird angle? Or have you just not tightened yet?
FJWALLY wrote: Fri Jan 21, 2022 9:13 am
Just mocked up mate, so I could get the sway bar link rod length close - waiting on bottom ball joints so the wishbone has to come back off
FJWALLY
Post by FJWALLY »
Cool Beans - what brand ball joints do you go with?
Blacky wrote: Fri Jan 21, 2022 10:55 am
Whatever they sell at Veales
Blacky wrote: Fri Jan 21, 2022 12:53 am
not sure, i do know that they are a bigger drop than 2" when used on a car that should be 13" wheels, i asked Rod about it once he didn't know there was a height difference between 13" and 14" stubs and said the 2" drop is based off a 14" stub so when replacing a 13" stub it's nearly a 3" drop
Got the ball joints in yesterday, finished off the sway bar links , refitted all the front end stuff apart from shocks because I don’t have any
After al this time I finally got the front end together and out of the 17495 wheels I have in the shed not one of the bastards fit ImageImageImage so I did my narna and pulled the drop spindle out and they STILL don’t fit ImageImage must be the offset of the P76 rotors , the caliper hits the inside of the rim, the only thing that clears the caliper is a commodore rim but it hits the top wishbone ….. FML
I ordered a pair of rims from BCI , hopefully they will fit Image
Handbrake cable rocked up today , and of course it didn’t fit either Image
The ends wouldn’t fit through the tubes into the rear drums , had to linish them up until they did , hopefully they don’t break….
Underneath is getting pretty close , brake hoses , clutch and fuel line and that ought to be about it
