I am hoping to use the best of the old rubbers I have. Clean them up and soften in sun. Alternatively, I have some formed v shaped rubber foam from Bunnings that could work too. Whatever gets used will have to be able to feed back in the gap once panel work is finished.oz_ek wrote: Tue Dec 28, 2021 10:01 pmGot a solution for this rubber?Brett027 wrote: Tue Dec 28, 2021 7:39 pm Floor work pretty much finished. Little bit to do under the hump and some general tidying up.
Other photos show work to be done. Not much now
Project 2.
Re: Project 2.
Re: Project 2.
Tidied up a few loose ends today in preparation for rear quarter work. A little behind schedule but doing OK.
Re: Project 2.
One down, one to go.
- 20211231_145401.jpg (3.04 MiB) Viewed 553 times
Re: Project 2.
Looks good
Re: Project 2.
Thanks Clay. Did 7 plug welds in behind. Can just reach it without the back cabin bottom panel sections, but I think I would be glueing it otherwise. I will POR15 all the lower 1/3 in that cavity, including the floor.
I emptied another Argon/CO2 this morning. That's 6 D sized bottles and one full 5kg roll of wire (and well into another roll) consumed so far. There must be a bit of welding going on
Re: Project 2.
Reckon so. I thought you should be able to get in behind. It’s the top bit worries me re warpage.
Re: Project 2.
All tacks, no beads and a wet cloth. No worries
Happy New Year from the crew at Project 2.
Re: Project 2.
Happy new year Brett, Kate and all forum participants.
FbSTDwagon
Re: Project 2.
Happy New Year Brett and all
Re: Project 2.
Re: Project 2.
A bit sidetracked today. Wet blasting K frames. A 'Unicorn' for Project 2 and a rusty norm for Black Ute.
2 pack etch coming up
Re: Project 2.
That's a damn fine looking subframe in the foreground
Re: Project 2.
Taken off a smashed rear end car in 1969 and shedded until I picked it up last year. Actually there are some pin holes right at the end of the firewall flaps that I could ignore or replace, but other than that it's perfect. The other one not so good....
Re: Project 2.
Treated and etch primed both sub frames to stop the rust. Photo of passenger side rear quarter patch. Some serious panel work for this side soon.
