Moderators: reidy , Blacky
funkyscooter
Posts: 702 Joined: Wed Aug 16, 2017 8:12 am
Post
by funkyscooter » Thu Dec 02, 2021 1:55 pm
Don't do it Brett! Keep the clutch - and show me how to do the firewall mod!
Liked the idea of the hinges - not so much the flex/cost/sub frame adjustment. And I do like the groan the springs make when I lift the bonnet - or is that just me?
What about Blacky's hinge mod? Would that give you enough room?
Scott
Posts: 2497 Joined: Thu Apr 18, 2019 4:14 am
Post
by Brett027 » Thu Dec 02, 2021 2:30 pm
I've had a look through Blacky's hinge mods and like the idea and the price, Scott. Will keep thinking....
Post
by Brett027 » Fri Dec 03, 2021 2:47 pm
First crossmember re-jig. It will be nice to get the front floor in, which is the next job on the list. Handbrake lever mount also to go on.
Posts: 11456 Joined: Sat Dec 06, 2014 2:44 pm
Post
by Errol62 » Fri Dec 03, 2021 3:07 pm
Tidy job
Post
by Brett027 » Tue Dec 07, 2021 5:53 pm
A bit more progress.
Working out how to set the tunnel up now. I'm thinking of making a curved right angle bracket for the firewall end and just butting on to the new flooring patches when they're made.
Currently the tunnel is not quite central to the crossmember brace (which I'm thinking it will be attached to eventually).
Lots to finish at this end of the car still.
Post
by Brett027 » Fri Dec 10, 2021 12:06 pm
What to do on a miserable rainy and cold day? Weld
62ekute
Posts: 645 Joined: Thu May 23, 2019 6:58 pm
State: ACT
Post
by 62ekute » Fri Dec 10, 2021 12:13 pm
Nice work Brett. Where'd you get those last couple of bits? Or did you make them? Patrick
Post
by Brett027 » Fri Dec 10, 2021 2:10 pm
Thanks Patrick- banged them out here. I don't have the big bead roller to do it properly but better than flat I guess.
The other side in place now. Got to knock off and do jobs now
Post
by Errol62 » Fri Dec 10, 2021 2:23 pm
Looking good Brett. Good on you mate.
Post
by Brett027 » Fri Dec 10, 2021 3:51 pm
Thanks Clay. One of those rare days where it all happened easily.
Had another kick-back with one of those poly discs today. I'm now thinking they are pretty dangerous except on flat panels.
Post
by Errol62 » Fri Dec 10, 2021 3:58 pm
Hell yes. Keep away from edges.
Posts: 2240 Joined: Wed May 16, 2012 10:18 pm
Post
by In the Shed » Fri Dec 10, 2021 4:22 pm
Great work Brett as always
Posts: 13981 Joined: Tue Jul 20, 2004 8:58 am
Post
by Blacky » Fri Dec 10, 2021 4:57 pm
Not a whole lot of the original floor left
Post
by Brett027 » Fri Dec 10, 2021 7:39 pm
Thanks Stephen. Blacky, you should see the rear pans- zip
Posts: 2773 Joined: Fri Jan 24, 2014 11:12 am
Post
by FireKraka » Sun Dec 12, 2021 10:49 am
Great work Brett truly inspiring
