Think I'm done with this. Needs paint, but I've gone over it with deoxidine and sealed it for now with easyphos so should be good for at least 6 months stored dry. Just got to find somewhere to hang it up. Look forward to having a bit more room to move.
Front had a few holes to fill, but apart from that it was just a bit (lot) of time on the wire wheel, powerfile, and die grinder.
- IMG_9030.JPG (607.52 KiB) Viewed 954 times
Inside just needed a tidy up where I opened up the front for the radiator. Bit of surface rust where the sides join the front, ground out as best as I could, wire wheel, then poured some Ranex in there to reveal what I had polished up and not removed. More grinding, wire wheel. Done.
- IMG_9044.JPG (681.09 KiB) Viewed 954 times
Now back to the firewall........
