Project 2.
Re: Project 2.
How about some custom body work on the ute Brett? Pair of sedan wings on gumtree near you:
https://www.gumtree.com.au/s-ad/bungend ... pasteboard
8 ) 8 ) 8 )
8 ) 8 ) 8 )
Re: Project 2.
Very near me Clay
- 20210901_111508.jpg (5.8 MiB) Viewed 674 times
Re: Project 2.
Brett027 wrote:Very near me Clay
FB Ute Stock
EK Ute in Pieces
EK Ute in Pieces
Re: Project 2.
Perfect kframe cuts off 'old rusty' ready to use to ensure firewall repairs are right and then later to repair kframe. Started opening up the can of worms to determine the size of the mess. It's not too bad. Hopefully get something repaired soon
Found more rust under front ledge of the ute tub behind the rear window. Can't see any problem from outside but the whole lot from one side to the other is gone underneath. Rotisserie job for later.
.Found more rust under front ledge of the ute tub behind the rear window. Can't see any problem from outside but the whole lot from one side to the other is gone underneath. Rotisserie job for later.
Re: Project 2.
Lucky Brett. They look pretty tidy.
Re: Project 2.
Can anyone tell me what this colour is called and maybe code?
Re: Project 2.
Started cutting up rust today. There will be many more days
This will be Fred's heater: a no nonsense model.
.This will be Fred's heater: a no nonsense model.
Re: Project 2.
Looks like Wedgewood blue. Not Grecian white?
Re: Project 2.
Bit of progress before smoko. Fiddly crap that takes a lot of time and mainly will never be seen.
Re: Project 2.
Ripping through it Brett.
Re: Project 2.
Looks a bit dark to be Wedgewood blue - could be Banff Blue like my ute or maybe Lucerne Blue
Re: Project 2.
Thanks Clay, Blacky. Sam has found a link to that picture that comes up with Banff as well.
Picture of a patch within a patch
- 20210906_134852.jpg (3.62 MiB) Viewed 564 times
Re: Project 2.
A bit of progress today. Much more to do....
- funkyscooter
Re: Project 2.
Wow - done by Christmas!! I spent most of my day welding small holes in the sub frame and procrastinating about if I should bother to cut out and replace the pitted metal around the battery tray. I know what I'd like to do, but I know what I'll end up doing.
Scott
Re: Project 2.
Hi Scott. What are you going to do?
I'm lucky this time; unusually no rust around battery to deal with. Got a bit done today but paid the price tonight. Can hardly move
I like this type of work. Not much thinking, just doing.
