Wilma FB project
Re: Wilma FB project
my bad - for some reason I thought they were up the B pillar :oops: for some reason I ran the wires up the b pillar in my ute I think , unless I am thinking about the HQ-Z utes that I have built ......
All good, no bad. These niggly little questions being sorted helps the next poor bugger to get through these checkpoints too. Thanks again everyone for your ongoing support.
My Melbourne FB ute ran up the b pillar. Adelaide ek van up the a pillar. With commercials b pillar is easy, apart from the foam stuffing. I recon my Adelaide ek standard ran up the b pillar, with no door switches. There was an oval shaped hole in bottom of pillars.
Blacky is right even though he may be a bit confused the Utes run the dome light up the B pillar I found that out the hard way with Frank and the sedans and others I suppose run up the A pillar form my small amount of knowledge.
funkyscooter
Post by funkyscooter »
Mine goes up the B pillar. Image
Scott
Scott
Yep, same as my EK215.
gpi
Post by gpi »
you can tell its not standard and that joseph owned it before you
Thanks Scott. Today I ran it up the A pillar. No new holes needed, just a bit of patience. I am pretty confident that originally it did go up the B pillar because the cut wires when joined together were the right length and position for that to work. I can also vaguely remember that oval hole. I did a lot of metal work on the bottom of the B Pillars so reckon the original hole was not reinstated in my plate work. I started trying to get a feed wire down the B pillar but just could not get it to go through. So just lengthened the wires and worked it through A pillar. Thanks again for the photos and advice on this one. I need to keep better records of original fetures in future.
Boot rubbers. Is this photo showing the right placement of the rubber?Image
62ekute
State: ACT
Post by 62ekute »
Hi Brett, it looks like it needs to rotate a bit more than where you are holding it. Patrick
https://811a3af5-a-62cb3a1a-s-sites.goo ... edirects=0
The orientation is correct. Rubber sits square in the channel of course but yes tail of the comma pointing in to centre of boot.
Thanks Patrick and Clay. Yes that's what I thought too. That photo was of the rear cut I had. Took the photo at the time as a later reference, but having a play today with Wilma's boot rubber I figured it was wrong. Lip should be facing in and standing up I hope. Rotated 45 degrees.
Errol62 wrote: Thu Apr 08, 2021 8:39 pmtail of the comma pointing in to centre of boot
I've heard a lot of blokes describe the way that seal fits, but that's the best description I've heard.
Yes Harv, Clay has a way with words 🙂. Question 606: I have two types of gear lever knobs- one is bigger than the other. Which one belongs on FB ?
Knobs
Knobs
If I could only translate it in to beer
