Floor pans
BowjayFB
Floor pans
Post by BowjayFB »
Good day fellow Fb Ek nuts.. I am doing front and rear floors in my fb have my Rare spars floor pans and was starting to nut it all out when I noticed the floor pans in the car have supports under them like a Chanel and these on both sides are both rotted out.
They look like floor supports ??my question is:
Number 1, what are they called ??
Number 2, can you buy repro ones or do I just make them ??
Any help would be great thanks..
59wagon
Floor pans
Post by 59wagon »
Hi Bowjay, do you mean part #38 below?
It runs across the car from sill to sill and includes the manual transmission hump hoop. You can buy the 2 straight bits from Rares, Taylor’s, etc. and they’re not too hard to make.
https://www.rarespares.net.au/perth/buy ... -ek-manual#
If yours are goosed, check the transmission hoop where the straight bits attach, as well as where they attach to the sills - very common spots for rust. There’s someone on eBay who makes the sills as well as the front bits that attach to the cross member, which are a bit trickier to make.
John
