Red Rattler Revamp
mph
Re: Red Rattler Revamp
Post by mph »
Is there a difference in size and hp needed to push the v6 or v8 vn vp t700.
What box will you be using mate.
FB-Special
Big block 161 :lol:
Holley sniper EFI.
Ek auto column shift.
Lj diff and reverse lights.
WA FB~EK Car Club Member.
V6 T700 that was very kindly donated by NoMad , who I believe is a VERY happy boy today 8) 8) 8)
gledge
Post by gledge »
Good stuff mate is that a sonic injection crank trigger set up I see there? What ignition are ya gunna run on it?
gledge wrote: Thu Nov 01, 2018 8:17 pm Good stuff mateImage is that a sonic injection crank trigger set up I see there? What ignition are ya gunna run on it?
Yes it is , bought a coil pack kit from Shane as well , think they are AU coils
mph
Post by mph »
Ah i see nice one mate thank's .
FB-Special
Big block 161 :lol:
Holley sniper EFI.
NoMAD
Post by NoMAD »
mph wrote: Thu Nov 01, 2018 1:26 pm Is there a difference in size and hp needed to push the v6 or v8 vn vp t700.
Both boxes can be built to handle, the V8 one can take more though. i was told they both suck similar power but cant confirm that
Also the VN VP V6 is a Buick pattern not turbo pattern... but behind a 6 an adapter would be required regardless
and you cut an ear of the box to suit starter motor mounting
Nathan
Foundation Member
Motor is all together now ready to paint , then I can throw it back in the hole so it can go to get some pipes made Image
Looking good mate :thumbsup:
WesternWagon
Post by WesternWagon »
Nice work, should liven it up a bit. :D
What’s with the different rocker arms?
Gazza
Member : Holden Car Club WA.
:ASRF Member
Two cylinders missing in my book but supercharged gets it over the line !!!
When we torture these engines on the race track they like to pull the caps away from the block and split the bores horizontally.
Keep the revs down and you should be right for a while anyway !!!
Gold rockers are tarnished from the exhaust heat :wink34: :wink34: :wink34:
PS don't mention pipes for a day or two please !!!
fbidek
Post by fbidek »
Hi Blacky, do you have any detail on the “HR front with Cortina rack and Landcruiser brakes” adaption? Sounds interesting.
60Special
Post by 60Special »
Looks like a few more gold teeth for the rat.
fbidek wrote: Thu Nov 15, 2018 10:38 pm Hi Blacky, do you have any detail on the “HR front with Cortina rack and Landcruiser brakes” adaption? Sounds interesting.
Will take some pics as it goes together mate, some of the lads in Vic are using this Cortina rack setup with good results , there was a guy doing the conversion in Vic but he is slow and impossible to get a hold of so I am going it alone , as for the Landcruiser brakes I have stolen that idea off Gledge , have a look at his build thread 👍
WesternWagon wrote: Thu Nov 15, 2018 4:28 pm Nice work, should liven it up a bit. :D
Gazza
They are off my old speedway motor , 1.6 on the inlet , 1.5 on the zorst
