wiper motor
- BILLY BLACKARROW
wiper motor
HI all
I had a problem with the wiper motor when I put the motor in the wiper motor was over the distributor the problem I have now is I am useing ( Brett_fs wiper motor conversion ) wired it as he showed but there isnt a park position it just stops where you turn it off I don't have a problem with that as I can turn it off at the bottom of the stroke BUT dose it have to park for engeneer & rego & if so how do I get them to park as there is no power after they are turned off (for some reasone the photo's are ass about but you will get the idea )
- IMG_1859.JPG (1.14 MiB) Viewed 1452 times
- IMG_1854.JPG (1.19 MiB) Viewed 1452 times
BILLY BLACKARROW
Re: wiper motor
Have you got the motor body earthed Billy? Can’t tell from the photos.
- BILLY BLACKARROW
Re: wiper motor
Yes motor is earthed
BILLY BLACKARROW
Re: wiper motor
Pretty sure the FE FC forum has a thread on this conversion using his switch and prestlite commodore motor. I remember reading it and thinking it sounded complicated (electrical idiot me). Good luck with it.
Re: wiper motor
I did this mod on my FC Sedan and it was easier than I thought (sorry errol) and mine does park, can only suggest you check your wiring again mate and as suggested check the earths.
- BILLY BLACKARROW
Re: wiper motor
BILLY BLACKARROW
Re: wiper motor
Re: wiper motor
I bought a VR wiper motor last week to do this mod , do you have a wiring diagram or any other info on the swap ???
Re: wiper motor
brett_f's Commodore Wiper Conversion
https://r.tapatalk.com/shareLink?share_ ... are_type=t
- BILLY BLACKARROW
Re: wiper motor
I just did what bertt_f said it was easy Errol 62 has put up a link to it thanks Errol 62
BILLY BLACKARROW
Re: wiper motor
Sweet - looks easy enough
- BILLY BLACKARROW
Re: wiper motor
There is still something wrong the arms move at differant rates doe's anyone have a photo of under the dash even stadard set up will help.
BILLY BLACKARROW
Re: wiper motor
Patked position. Sent from my iPhone using Tapatalk
Re: wiper motor
Billy I had the same problem I lengthened the drive arm, the first one on the wiper motor that has the two bends, goes from wiper motor to the piece that joins the two arms together.
I lengthened it by about 5 or 10mm (can't remember) this was on my FC, they don't stroke exactly but pretty close.
I'll see if I can get a photo for you.
- BILLY BLACKARROW
Re: wiper motor
Errol62 / could I get a photo of each end as well mark photos as left & right from your photo it looks like I have the arms ass about but not shaw how they are going to go around the heater vents
Niel / some photos from you would help to
At the monent I don't know what is wrong every bit will help
Thanks for your help Guys
BILLY BLACKARROW
