There are some photos of my engine bay in this thread:
http://www.fbekholden.com/forum/viewtop ... 3&start=75
I used a VL Commodore 6-cylinder automatic radiator - same core size as a VK Commodore 308, so should cool the 327. Had the radiator recored as it sat idle for a long time.
I took the standard radiator support brace, and cut about 15mm of recess into it (Dave then got handy with the welder and put a skin on the recess). I widened the frontal area by cutting back the two subframe radiator side flaps a bit. I used a 2' length of angle iron down the bottom, bolted to the subframe sides, as a bottom support. The two radiator bottom pins sit in holes in this support. The two radiator top support pins sit in angle iron brackets, bolted to the subframe.
I've got two of the smaller size Davies Craig thermos in front of the radiator, with no engine driven fan. Had to cut a little bit off the bonnet catch to get the fans to sit up so high.
