My second ek
Re: My second ek
Good progress Toey. Keep the passion mate.
Re: My second ek
Done a experiment with a product that claimed that it ate rust and returned rusted parts back to clean bare metal it's come in a liquid and a gel I had to use the gel on the body so it was dearer but a little bottle of I think 100ml was $13 so for a experiment I gave it a go as I have always been sceptical on rust products. I did end up doing it a second time to fully clean the metal but it did work so saved sand blasting and having garnet everywhere
The product
Experimental patch
After 24hrs
Cleaned the whole side up super nice after two 24hr applications
Picture of the other side shows how it would of been originally
Sent from my E5823 using Tapatalk
The product
Experimental patch
After 24hrs
mmmmmmmmmmm dunno
Re: My second ek
Good stuff. I need a big tub of it to dip my van in.
Re: My second ek
Funny you say that on there website there is a guy that made a sprinkler system out of the garden sprinkler systems you get from hardware shops and set it up over his carErrol62 wrote:Good stuff. I need a big tub of it to dip my van in.
mmmmmmmmmmm dunno
Re: My second ek
I'm lost for words
the rocket
Re: My second ek
Does it peel off or leave residue on the metal that needs cleaning ?
Re: My second ek
the gel wiped off and is easily cleaned up there are directions on the bottle on how to clean its very similar to de-oxidine but i also went over it with a wire wheel and orbital just to finish it off then still applied a de-oxidine afterwards.the rocket wrote:Does it peel off or leave residue on the metal that needs cleaning ?
mmmmmmmmmmm dunno
Re: My second ek
Now that sprinkler system is thinking outside the box for sure! The next time I go to the hardware I'll be thinking how could I use this part or that part for my next shed project. Thanks for posting that Toey!
- Contact:
Re: My second ek
Re: My second ek
Yeah the product can be re-used i know with the gel if it is still blue you can reuse it if green it's ok if black it's fubarparisian62 wrote:Bit of Aussie ingenuityl Looks like he can collect it from the floor and recycle too?
mmmmmmmmmmm dunno
Re: My second ek
Just some filler of course we all know these old cars have no bog so mines special
Finally got something sealed up so it can sit and I can forget about that little bit
Well been a long time coming and the panel still isn't totally finished but I will keep tinkering and keep slowly progressing
mmmmmmmmmmm dunno
Re: My second ek
Good work, keep it up
re the rust treatment,i tried some lemon juice off the tree out the back
i came back a few days later and it was just as rusty but a sticky mess.
kmawic
Re: My second ek
Most acids will reduce the rust but when left to long they make it worse that gel I used was great but then all metal is treated with a metal conditioner which is basically phosphoric acid but once applied the steal must be sealed with a etch or epoxy primer problem with just sealing with a etch is that it is a very pourus primer, 2 pack epoxy has excellent adhesion to bare metal and isn't pourus I deoxidined (metal conditioner) before applying my filler but gave it a good sand before filler went in with 120 on the orby
mmmmmmmmmmm dunno
Re: My second ek
Seems that over night the car was even impressed with a coat of primer
mmmmmmmmmmm dunno
Re: My second ek
Life would be easier if I had my rotisserie back lol
mmmmmmmmmmm dunno
