8 inches of pleasure
does anybody have 8"wheels on the rear of there car with NO inner wheel well modifications and NO flares on the outer wheel arch, lip mods and a bit of pumping is ok, also car must sit low no jacked up to clear cars either
now that that is covered if so what offset and size tyres are you using, that of coarse if anybody has it
Thanks
Re: 8 inches of pleasure
Nope, had 7's with 245/50's on the rear of my ute with the outer lip cut off. Rubbed on the inner wheel well when cornering.
see 245 is a big tyre it would have bagged out on the rim atleast if not more than 1/2" each side so a 8" rim with a smaller tyre that's square to the rim should go i've had 10"rims with 235x50 tyres on one years ago but there was more rubbing than i want these days, don't mind some rubbing on the inside up driveways etc
Yeah they did a little. I also had 2" blocks in the back. Forgot I had a pic!
cool thanks
sucks shelling out good money on wheels when not sure if they'll fit :(
wot179
Post by wot179 »
You can borrow my ones to check offsets if you want, Mick.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
got some on the austin it's just a matter of getting access to it and then leaving it without a wheel or wheels
