HT INTERIOR MIRROR
HT INTERIOR MIRROR
Hi Guys, Im just doing a bit of rust work around the windscreen of my HT wagon but cannot find how to remove the interior mirror. There are no screws and I dont want to use force. Any suggestions ? Regards Daz.
EK DAZ
Re: HT INTERIOR MIRROR
pretty sure its a grab and pull backwards and it should pop out (95% sure)... then you just give it a tap with your palm to pop it back on...
either that or theres 1 or 2 tabs and you can lever it off one side with a screw driver then it will pop off... but above sounds right from memory
cheers
Nathan
cheers
Nathan
Foundation Member
Foundation Member
Pretty sure the same as hq they pop out when pushed sideways eg get the stem and hit it towards side and it will come out.
Yep, that's the way I have always done it
